Please offer the option to utilise MiBand 8 utilising the new app revision ‘Notify for Xiaomi’ which covers Miband 7 Pro upwards.
Hello Bob, the integration with MiBands completely relies on what the companion apps can do…
Direct integration is not possible, the Notify app developer must use tons of hacks, BT sniffing, and reverse engineering to make it work. There might be some limitations, especially for the real-time data flow.
Let me ask Matteo if the newly added integration of MiBand 8 applies to Sleep integration too.
