Some research seems to support the idea that setting your alarm for 90mins before you need to wake up, and simply snoozing your alarm for 90 minutes provides you a better sleep than other methods. Would love to easily utilize this info, but the snooze timer seems to only go up to an hour. I Tried This 90-Min Wake Up Hack for a Week — Here’s What Happened
Hello @Crim_Sama.. I’m adding the 90 minutes snooze option for the next version of the app.. you can join the BETA channel to get it earlier..
After that you should be starting receiving latest BETA updates through the Play Store.
