There are some features in the “alarm default settings” that do not exist in the options for an individual alarm.
For example these features (not-conclusive) should allow alarm-individualization, but currently do not:
- Backup alarms
- Play alarm in silent profile
- Jet lag prevention
- Alarm output
Similarly, there are some features that are can be changed in the options for individual alarms, but there is no way to set a default under “alarm default settings”.
- Delete after ringing, Terminate tracking
- Maybe allow setting a default time or repeat pattern?
Similar Issues
| ID | Created | Status | Link |
| 663 | Mar 11, 2016 | Migrated, Open | Add the “not before ideal sleep” feature to the per alarm settings |
| 1219 | Sep 8, 2017 | Migrated, Open | Allow “Changing snooze time” toggle to be set per alarm |
| 1472 | Sep 8, 2017 | Migrated, Open | Allow “Changing snooze time” toggle to be set per alarm |
Requests aside, thank you and the Urbanandroid team for creating a wonderful product!
