From Cezary Drożak on 2016/05/10 10:08:02 +0000
When the screen is dimmed the on-screen buttons are always on and I’m afraid that it will cause screen burning. Please make the app go to immersive/full screen mode when dimmed.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/13793208-immersive-mode-when-screen-is-dimmed
From Petr Nálevka on 2017/08/10 08:06:34 +0000
Adras, when screen is dimmed in sleep tracking (after 20s) the navigation bar get hidden as well, does that not happen on 1+?
Othrwise there is always your device screen timeout which will turn off screen and also prevent overburning..
From András Pozsgai on 2017/08/09 17:37:48 +0000
I am using a OnePlus 3T and my AMOLED screen is burned in. possibly because of this feature. I used an app to fix the burn in, now it is not visible anymore, but I don't want it to burn in again. The notification bar disappears, but the nav bar stays on the screen.
