iLumi smartbulb integration
From Hensley Beuron Garlington on 2016/05/13 03:01:41 +0000
I would like to use my Android Sleep app with my iLumi smartbulbs. They already have an alarm like illumination mode that your wonderful app just needs to take advantage of. Be nice to have smart wakeup work with iLumi bulbs.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/13828893-ilumi-smartbulb-integration
From Chris on 2016/10/05 17:23:32 +0000
Came to suggest the same thing just now! Seems that Phillips Hue is supported by lots of apps, Ilumi support would be fantastic.
