I had to solve Captcha (not at home) when I was not at home - Sleep as Android
Not at home feature only works when we see your location is significantly different from the home (±5km at least), as we do not collect fine location for privacy reasons.
This is a companion discussion topic for the original entry at https://sleep.urbandroid.org/docs/faqs/at_home_catpcha.html
I understand; however, how can I ensure that the configuration for it is correctly set in my app?
Hi @Andre_Cruz, open the list of graphs (Left ≡ menu → Graphs), and long-press one of the entries with #home tag. From the menu, pick Show on map , and the app will show you the approximate location considered as your home (due to the privacy range, it won’t be exactly your address).
