How to splitting a 2-day recording
I had a long continuous sleep that spanned 2 days. So the report is only recorded on one day. I’d like to separate them and reallocate to each day they refer to.
Unfortunately, I haven’t found an answer in the help section or in the forums.
Thank you in advance for your help.
Hi @Alzinch, the graph is rendered from the data set. So the graph cannot be merged with another graph, or split into two graphs.
At the moment, it is probable only possible to remove the time from the graph from one of the days, and add the remaining sleep time manually. I am sorry for the limitation.
