I remember there was an option to set your own sleeping duration. For example, if you think your sleeping duration is actually 6 hours and you set your alarm to 6:00 it won’t bother you at 23:00 that you need to sleep.
Hi @Paul1
Go to Settings > Bedtime notification > Ideal daily sleep
