You might find Tidabie Music Go incredibly useful. This program is for personal use only. It works for free SoundCloud account.
Tidabie Music Go is a one-stop music converter designed for downloading music from popular music services like Spotify, YouTube Music, Apple Music, Amazon Music, SoundCloud, Pandora, etc.
Here is a short tutorial.
STEP 1: Launch Tidabie Music Go and select “SoundCloud” from the “Music” module. Then log in to your SoundCloud account in the built-in web player.
STEP 2: Go to the “Settings” dialog. Here, you can customize the output format, quality, output folder path, etc. The provided options for output format include MP3, AAC, WAV, AIFF, ALAC, and FLAC, and the changeable options for quality include 128 kbps, 192 kbps, 256 kbps, and 320 kbps. Here, you need to choose MP3 as the output format.
STEP 3: Back to the SoundCloud web player to add tracks to download. Find the needed tracks and hit the “Click to add” button to parse music. Then tick the tracks you like from the list and tap on “Add”.
STEP 4: Click on the “Convert” button to start downloading SoundCloud tracks to local PC.
STEP 5 Go to the “History” module to check the downloaded music once the downloading process is finished. You will see the music is saved in MP3 format.
