If you own an MP3 player and are looking for ways to put Tidal on MP3 player for listening on the go, then all you need is to convert Tidal to MP3 first. Let’s see the following best way to get Tidal music on MP3 player.
You should know Tidal applies DRM technology so you can’t play Tidal songs without the Tidal player. Although you downloaded Tidal tracks for offline listening, they are not physical files in your local folder. So to play Tidal on MP3 player, you have to use a Tidal Music converter.
Here, I use Tunelf Tidal Music Converter to help me download songs, playlists, and albums from Tidal to MP3 and other DRM-free formats. Moreover, this tool is able to download Tidal songs even if you are a Tidal Free user. In the process of converting, Tunelf can keep the lossless sound quality and retain the original ID3 tag info. Thanks to this function, you can better manage your converted Tidal songs and have a lossless experience.
Key Features of Tunelf Tidal Music Converter:
Download any Tidal content, including songs, albums, playlists, and artists
Support exporting Tidal music to MP3, AAC, FLAC, WAV, M4A, and M4B
Preserve a whole set of ID3 tag information in the downloaded Tidal songs
Handle the conversion of Tidal music up to 5× faster speed and in batch
To download Tidal to MP3 which is supported by MP3 players, just use 3 buttons to finish the process with Tunelf.
Step 1. Add Tracks from Tidal to Tunelf
Just copy the URL link of the song or playlist from Tidal and paste it to Tunelf to upload songs.
Step 2. Configure the Output Format
Click the Menu icon and then go to Preferences to set the output format as MP3. You are also allowed to change the sample rate, bit rate, channel and other parameters.
Step 3. Initiate the Conversion
1-click the Convert button and you will get Tidal MP3s in a few seconds.
Step 4. Transfer Tidal MP3s to MP3 Player
Now, use a USB cable to connect your computer and MP3 player. Then move these playable Tidal files to MP3 player for listening.
To play Tidal on an MP3 player, follow these steps:
1. Understand the Challenge
Tidal uses DRM (Digital Rights Management) protection on its music, which means you can’t directly transfer songs to devices like MP3 players that don’t support the Tidal app.
2. Use a Tidal Music Converter
To make Tidal tracks compatible with MP3 players, use a third-party tool like DRmare Tidal Music Converter. This tool removes DRM and converts Tidal songs into MP3, FLAC, WAV, or other common formats.
3. Steps to Convert Tidal Music:
Download and Install: Install the DRmare Tidal Music Converter on your computer.
Log in to Tidal: Open the converter and log in to your Tidal account.
Add Songs/Playlists: Drag and drop songs or playlists from Tidal into the converter.
Choose Output Format: Set MP3 as the output format and customize the quality, bitrate, and other settings.
Convert: Click the Convert button to start downloading Tidal tracks as MP3 files.
4. Transfer Music to MP3 Player:
Connect your MP3 player to your computer using a USB cable.
Locate the converted MP3 files on your computer.
Drag and drop the files into the MP3 player’s storage.
Thanks for sharing! To play Tidal music on an MP3 Player, the most important step is to download it as an MP3 file from Tidal. This requires the help of some third-party tools. I am currently using TuneCable iTadal Music Converter. It is specially designed for downloading Tidal songs, playlists, albums, etc. It is very easy to use and the download speed is very fast. Worth a try.
If you are seeking guidance to stream Tidal’s master quality music in MP3 format to play on your MP3 player, Tidabie Tidal Music Converter helps a lot.
Tidabie Tidal Music Converter is an excellent tool that can assist you in downloading Tidal master music to MP3.
Follow it step by step.
STEP 1: Launch Tidabie Tidal Music Converter and Select a Recording source: Tidal Web Player or Tidal App (higher audio quality). To download Tidal master quality music, you need to select the Tidal app source. Then log in to your Tidal account.
STEP 2: Direct to your favorite master quality music on Tidal, then click on the blue “Click to add” icon located in the lower right corner. You will then see the tracks listed on a new window. Just tick the preferred ones and tap on “Add”. If you would like to add other songs from different playlists/albums, you can click “Add More” and repeat the adding-song actions.
STEP 3: Navigate to the “Settings” section, you can customize output parameters here. Adjustable settings include conversion mode, output format, bit rate, sample rate, output file name, and more. In other to get Tidal master quality music, we recommend choosing “Auto” or “FLAC” format, and “Tidal Record” in the “Conversion Mode” tab.
STEP 4: Hit “Convert” to start the conversion. Once the process is complete, you will see the output folder that contains the downloaded Tidal master music files.
