How to Play Deezer on Amazon Echo
As a must-have service in our daily life, music plays an important part in our entertainment. Except most-famous ones like Spotify, Amazon Music, and Deezer Music still have a place in the market. Though it is not as famous as other streaming services, it was one of the oldest ones for online music streaming and is still ranked in the top 5 now. Amazon Echo is a popular digital speaker for home theater. A lot of people are wondering about the possibility to stream Deezer on Amazon Echo .
So, does Deezer work on Amazon Echo? If yes, how to add Deezer on Amazon Alexa Echo for a better playing performance? If you’re eager to know the answers, then you can’t miss this post!
Part 2. Stream Deezer on Amazon Echo via Official Way
Now that Deezer has built partnerships with Amazon Echo, we can connect with each other directly. Deezer is now available on all Amazon Alexa devices, including those Alexa-enabled devices. To figure out if your device is of this type, go to Amazon.com to search for compatible Amazon Alexa devices. Remember as long as you’ve connected your mobile devices to Alexa Echo via Bluetooth, you can stream any audio like Deezer, Spotify, or YouTube through your Alexa devices. Here is how to set up Deezer for Amazon Alexa Echo, this will need an Alexa app.
[Note]: The Hi-Fi (FLAC) streaming is NOT available for Deezer on Amazon Alexa.
  1. Open the Alexa app and tap menu settings.
  2. Select Skills & Games and search for Deezer.
  3. Select Deezer and tap ENABLE TO USE .
  4. Enter your account credentials to log in.
Use voice commands to control Deezer on Amazon Alexa
Since Amazon Alexa Echo is artificial intelligence with a voice assistant, you can completely control the music playback on Deezer through some specific voice commands. With Deezer on Amazon Alexa, you can play a song or song without lifting a finger. You should make voice commands by saying “Alexa” as a start like “Alexa, play (song/album name) by (artist) on Deezer”, “Alexa, play my Flow on Deezer”, etc. Besides, you can ask more from Alexa, like to tell you what song is playing, skip to the next track, and change the volume level with these commands. Such as commands like “Alexa, what’s playing?”; “Alexa, next song.”; “Alexa, I like this song.” If you do not want to say “on Deezer” every time you play a song, you can set Deezer as your default music player on Echo.
Set Deezer as the default music player
If you’re tired of playing music by saying Deezer’s song name “on Alexa”, you can choose to set Deezer as your default music player. Then, next time you can simply play a song by asking “Alexa, play [song name]”. Here’re the steps:
  1. Open the Alexa app menu and select Settings .
  2. Under ALEXA PREFERENCES, select Music .
  3. Next, go to ACCOUNT SETTINGS and select Default Services .
  4. Select DEFAULT MUSIC LIBRARY > Deezer .
  5. Once completed, you’ll see a checkmark shows up.
Part 3. Exclusive: Download Deezer Music for Playing Anywhere
As we all know, Deezer’s music prevails in its splendid music quality. Unlike Spotify, Deezer offers one more plan for subscribers, which is the Hi-Fi plan which plays lossless FLAC audio files at 16-bit, 1,411 Kbps. This part is going to introduce a tool to download Deezer audio files offline with lossless Hi-Fi quality and meanwhile allows you to stream Deezer tracks on multiple devices.
This efficient method is by using Tunelf Deezer Music Converter. Tunelf Deezer Music Converter is mainly used to help all Deezer users download Deezer music songs and playlists including HiFi tracks to MP3, AAC, WAV, FLAC, M4A, and M4B formats with high audio quality and fast speed. Whether you are Deezer Free users, Deezer Premium users, or Deezer HiFi users, you can download music files from Deezer to your computer.
UkeySoft Deezer Music Converter is one of the best Deezer Downloaders. It supports multiple formats, including MP3, M4A, WAV and FLAC, allowing you to get Deezer playlist for free forever. This means you can enjoy Hi-Fi playback offline anywhere.
It offers fast download and conversion speeds, supports batch conversion, and has a simple, user-friendly process. You can drag and drop files or add entire playlist directly for conversion. It also allows you to customize output settings, such as format, bitrate, and sample rate.
If you’re a Deezer paid user, downloading music on Deezer is the best way to play Deezer music offline. But if you’re a free user and don’t want to spend a lot of money on subscriptions, TuneFab Deezer Music Converter is the fastest way and your ideal choice.
