I have a Mi Band 3 with latest firmware and Notify&Fitness-App and need some help with getting heart rate monitoring to work with SaS.
SaS is configured to use Mi-band with Notify-App and I also enabled the heart rate checkbox.
But it seems that only movement is recorded during sleep tracking. In Notify-App itself I am able to measure heart rate without problems.
Notify&Fitness has different settings for heart rate monitoring - what do you recommend / what is known to work?
Contineous monitoring - do I need to enable that? It’s disabled by default. I tried 30s but still no heart rate in SaS
Heart-Rate measurement mode: can be set to “Mi band only”, “Notify-App only”, and “both”. Default is the second option.
Sleep-tracking-enhancement - I have no clue whether this should be enabled for use with SaS or is only relevant for Mi-Band built-in sleep tracking… It’s disabled by default.
Is there anyone with known-to-work settings?
Edit: I have the non-pro version of Notify-App..
