How do i only enable sleep tracking for a specific alarm
Hi
I’ve tried to enable sleep tracking. it also works for the most part. but now I tried to disable it but it keeps reactivating even though everything is set to manual. Also, how do I only set it up for one alarm?
Regards
Hi @Ephreal, if the tracking is set to manual, it should only start after your manual intervention. Is it possible that automatic tracking is enabled in the Phaser section?
Could you please use the Left ≡ menu → (?) Support → Report a bug?
An award-winning podcast from Google about the unseen world of data centers.
Great Maui Land Grab Book
They really made me feel confident in my choices.
custom cabinets cape cod
The website provides a good user experience with essential features readily available.
