How do I *import* sleep data from Fit to then export to Calendar?
I used to use Sleep as Android with my smartwatch when at home but now I only usually use it when I’m traveling for work (I tend to do it often). However, at home I use the Nest Hub that automagically inputs my sleep data in Google Fit.
Usually at home I do not wear my watch to bed anymore, which leaves me with a weird situation that some days my sleep calendars are guessed/empty by the Sleep app, and when I am traveling, the event timelines are accurate.
What my question is:
Since Google Fit has the ability to do a two way sync with Apps (as evident by Calorie counter apps), how do I import my sync data from Google Fit to Sleep as Android? I just want the Sleep Calendars to be normal again.
Thanks
