From Anonymous on 2014/12/05 11:37:13 +0000
Dear developer
First of all, thank you for an amazing app ! I use it primarily to record my sleep talking, and it is the best app for the job, without a doubt (except from the audio quality). The only change I could wish for is that the quality of the ogg encoding could be set even higher. Vbr 256 kbps would be great. I sometimes record with an external Mic, and I believe it could benefit of the higher bit rate, especially if any post production is to be done.
I hope you will consider making this an option !
Best wishes
Hannibal
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6806069-higher-bitrate-ogg-256-vbr
