I have Mi Band Tools and Nofity & Fitness for mi band both the applications, now if I want to specifically use Notify and Fitness application and Not Mi band Tools with Sleep as Android is there any way to do that.
If not please add an option with allows user to connect Sleep as Android with a specific application for wearable tracking.
This is a request I’ve been waiting for! You’ll be very pleased to hear that I’ve implemented this two weeks ago and currently it is going through the beta - will be there for you in the next update.
The option will be in Settings > Wearables > Use wearables - where currently is just a tickbox, a selection dialog for a specific wearable (and in the case of Mi Band, wearable with a specific app combination) will be.
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
