Health Connect - Sleep as Android
Allows you to synchronize data between Sleep as Android and Health Connect.
Export of your sleep phases from Sleep
This is a companion discussion topic for the original entry at https://sleep.urbandroid.org/docs/services/health_connect.html
It took me almost a month to understand problems with SpO2 not read from the Health Connect. Hopefully, it will help someone. If you have a lot of data already there, new apps, including SAA cannot read SpO2 because the quota exceeded error. To solve this, go to Health Connect and delete SpO2 data. It allows to select for which period you want to do that. Unfortunately, I had to remove everything.
