Health Connect - Sleep as Android
Allows you to synchronize data between Sleep as Android and Health Connect.
Export of your sleep phases from Sleep
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org/services/health_connect.html
Does not automatically syncs to Health Connect. Have to go into Services and manually sync. Tried toggling the permissions and the service in settings, but didn’t help.
Hello, sync with any health service happens only when data change and only if last synchronization is happend enough in the past.. to be gentle to our quotas.. if you use menu > report a bug we will investigate the issue in detail..
I have not managed to get this integration to actually sync sleep data to health connect, for now I rely on sync with fit, that sync it further to health connect.
