GPS driven function to enable or disable alarm
From Marco Russo on 2016/04/24 22:55:03 +0000
A function to disable or an enable again the alarm when you’re in a different place than normal. For example if you’re in holidays you don’t need to disable your morning alarm.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/13572354-gps-driven-function-to-enable-or-disable-alarm
