Are there plans to integrate with the new Instinct 3? The 2 is supported but it doesn’t seem to work with the 3.
Hello @JayHenMac .. I have made a new build of the app with support for instinct 3 and few other new devices.. it is now in review and should be available shortly from the Garmin app store..
Thank you very much! That was quick. I assume I am not the first requester.
@JayHenMac I think you are :).. the SDK with support for instinct 3 was just release in late December..
Thanks for the update! I was able to install the app to my watch.
There seems to be an issue with the latest version of Android OS.
The phone app is prompting me to fix the battery optimization. In the latest version of Android OS, this option is no longer available. When you select “fix” > “App info” > “App battery usage” the only available option is now a toggle to “Allow background usage”.
When I allow for the background usage, the app seems to work (i believe) but I am still prompted to fix the issue.
@JayHenMac many thanks… yes Allow background usage it the right option to go for on newer Androids.. is the prompt annoying?
It seems that in the latest release it dropped supposed for the instinct e. Is there any reason for that?
