Garmin Forerunner 265
Hello, a long-term user here. I just upgraded my smartwatch from Samsung Galaxy Active 2 to Garmin Forerunner 265 and have discovered the Sleep app is not compatible with the Garmin watch. Would it be possible to add support, please? I love the integration and want to avoid using stock alarm app. :slight_smile:
Thank you!
It is? https://play.google.com/store/apps/details?id=com.urbandroid.sleep.garmin
Yes, thereโ€™s a Garmin add-on in GP. The issue is that itโ€™s required to install a companion app on the watch as well, and the app (available from Garmin IQ store) is sadly not compatible with the latest Garmin model(s).
Hello, many thanks for reporting, this is a new model and we need to explicitly declare support for each model. My collegue @jiri-urbandroid is adding it, so you should be able to install the watch app soon..Many thanks..
Hello @Hardy this should now be released.. does it work for you?
