Food times
From Henric Sandell on 2016/12/30 20:19:22 +0000
I would like to have a functionality where I add when I have eaten and also what. This should then be integrated into the statistics so that it can be used for enhancing sleep by determining if there is any certain times or food that is better or worse for my sleep.
The times and what have been eaten should be separated into two different inputs to the statistics. The time can be added simply by a watch and with a date picker (so you can add it the day after or two if you forget).
What you have eaten could use tags so that you can easily add and reuse - this would then be simplified with the other suggestion about a tag manager, to add and keep track of tags.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/17580721-food-times
