Feature Request: Cillso T80 / Glory Fit Integration for Sleep Tracking
Dear Urbandroid Team,
I am writing to inquire about the possibility of adding support for the Cillso T80 smartwatch, or more broadly, integration with the Glory Fit app, to your sleep tracking applications
I currently own a Cillso T80 smartwatch and use it with the Glory Fit app. Furthermore, I am very interested in using your sleep tracking software, but it appears that neither the T80 directly nor the Glory Fit app are currently supported as wearable integrations.
Being able to use my Cillso T80 for sleep tracking with your application would be a significant improvement to my sleep monitoring setup. I believe that adding support for this popular watch and/or its companion app would be beneficial to many users.
Is there any possibility of adding support for the Cillso T80 or a Glory Fit connection in a future update? If so, is there a timeline for when this might be implemented? If not, are there any workarounds or suggestions you can provide for using my smartwatch for sleep tracking with your app?
Thank you for your time and consideration. I look forward to hearing from you.
Sincerely,
Lberondroth
Hi @Lberondroth, integration depends on the API. We need access to the raw data in real time, directly from the sensor. Do you know of an open API? I couldn’t find any manufacturer’s web.
