Feature Request: Allow disabling of screen lock during alarm
Hi, After this newest update, I can’t use split-screen to solve math problems with calculator. Previously, I could use difficult math to avoid oversleeping, which required the use of the calculator to solve problems and disable the alarm. I can no longer do this, which means I have to find an external calculator to solve math problems. This makes disabling the alarm very difficult when I am away from my home, as I often have no other calculator to use for this purpose.
Could you please add an option to disable this screen lock function?
Thanks
Hello Ken, sure please disable Settings > CAPTCHA > Chaptcha cheating protection…
