From Germo Görtz on 2016/06/29 13:21:42 +0000
In case the Connection to the smartwatch is lost nothing is recorded, and nothing is transfered from the smartwatch to the phone later.
A buffer on the smartwatch (Android wear) would be fine.
Or a fallback to use the Smartphones sensor in case the Connection to the smartwatch is lost.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/15025002-fallback-to-smartphone-sensor-if-smartwatch-connec
