From Jay on 2014/09/24 02:58:20 +0000
Could we get extended lullaby durations? I know the max is 2 hours, but could we get perhaps a longer duration? Maybe even the ability for it to last the entire sleep duration. Also, a feature where when we set an alarm we can also select a lullaby to play during sleep that automatically plays as soon as we begin slumber. That way the user doesn’t have to go through all the menus to select a song, which could affect any sleepiness the user is already experiencing.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6478050-extended-lullaby-sound-duration
From Anonymous on 2015/05/16 08:05:33 +0000
It aint even 2 hours! The max duration is only a hour and a half… im requesting the same thing, im so tired of dosing off and then hearing the lullabie start fadding out so i gotta move an spend another 90 to fall asleep, and hole time im trying to sleep i keep thinking "i hope the lullabie dosent fade out yet" "how much longer till it fades should i reset now" not acceptible.
Same, I suffer from tinnitus. Would really like it if it could run all night. Then I wouldn’t have to restart it if I happen to wake up in the middle of the night.
Hello Charles, the Turn off when sleeping feature can be disabled in the settings, so the lullaby will play till the tracking termination. If your lullaby stops suddenly in the middle of the night, the app is probably struggling with the system restrictions. Please check https://dontkillmyapp.com/.
