From Sondre on 2017/01/11 17:23:14 +0000
Function to set the alarm to go off every 3rd - 4th - 5th week. So i dont need to change the alarm every week
currently working 4 shift.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/17694352-every-2-6-week-alarm
Can you please advise how you’d set up an alarm to be every 1 in 3 Saturdays?
I work 2 in 3 weekends, so if I set up 2 alarms that are get every 3 weeks it works out.
support conversation with Andrew
