From Randy Tasajaya on 2016/03/22 23:16:28 +0000
Let me first thank you for developing the app so carefully.
The “smart bedtime notification” is a genius and problem-solving idea. I bet a lot of people want to use this setting, I personally use it to reduce my sleep deficit. But on weekdays, some people need to do works / activities, which don’t let them to sleep earlier; on the other hand they would still want to reduce their sleep deficit. Hence the solution:
The “smart bedtime notification” can be set to only on weekdays/weekends, or even on which particular days,
on which the user has the possibility to sleep earlier (user defines this by him-/herself by this new setting).
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/13076604-even-smarter-bedtime-notification-setting-on-whic
