From Robin Markowitz on 2016/03/26 02:49:19 +0000
I wish I could import Sleep As Android data into the great statistical app called “Sleepmeter.” But it only takes either Sleep Bot or an alarm from Gentle Alarm. I can’t figure out how, as a fan of both apps, to encourage a developer about the superiority of Sleep As Android. And suggestions as to how to go about it? It should be easy to implement. Can it be done from your side? Through an export function? I don’t think so, but you never know. It might already be available if I knew where to look. Thanks.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/13138776-encourage-sleep-diary-sleepmeter-to-integrate-wi
From Robin Markowitz on 2016/04/15 16:42:15 +0000
If Sleep Bot imports data from other Sleep trackers, I could export the SaA data to S.B. and Sleepmeter would never know. But only if they have an import function. I am going to download and find out; if not, I'll just get rid of it.
From Petr Nálevka on 2016/03/28 14:59:56 +0000
+Robin, sorry this will fail.. SB format is different than ours..![]()
