Wonder why is it so and what it means?
Hi @StirnaGun, this is a bug in one of the Material You components. We tried to overcome it, but have not found a reliable solution so far.
Do you use Tabs are you home screen layout?
Hi Lenka,
Thanks. No worries. Can live with it. Didn’t understood your question “Do you use Tabs are you home screen layout?” though. Was it about long screenshot?
I was asking about the Home screen type - we have either Dashboard or Tabs. We suspect this might be more common in the Tabs layout. Do you use Tabs? And if yes, which tabs are active?
