[DONE]Skip next/skip until
Add a feature onto skip next that lets you skip a certain number of days or skip until a certain date. Great alternative to turning off alarms for holidays/breaks that avoids the issue of forgetting to reset alarm.
This could be a 3rd option in the “are you sure?” popup after selecting “skip next”
Many thanks we will consider it… please note that you can already skip for multiple days although it is quite cumbersome… if you long press an alarm you can choose skip next multiple times and skip a week ahead or more…
Great idea :blush:
Hello, this topic is a bit older, but we would like to let you all know, that the alarm for specific dates are now available in BETA version for testing, if anyone is interested.
After that you should be starting receiving latest BETA updates through the Play Store.
To discuss BETA channel related issues please use our forum at: https://forum.urbandroid.org/c/beta
