[DONE] Improve TAG with a TAG Manager
Hello, we show tags that have been used in the last month as a convenience for quickly adding the tag, but of course you can write the tag in yourself..
Is there a setting where we can enable the listing of all tags we have ever used, rather than shortened list of the most frequently used tags? For example, in the past I have created a tag ā€œchamomileā€ and then because I can’t see it in the list (because I rarely drink chamomile), I have created a new tag called ā€œteachamā€ or something similar. A shortened, most-frequently-used list is elegant, but it would be great to give the user the option of easily finding and using infrequent tags.
I concur. A tag addition to the #snore, #laugh, #baby etc., Would be useful when reviewing the recordings to identify the sounds created when one rolls over or moves during sleep. The sound is recorded but adding a tag manually is very akward.
Hi all, I’m just release a very simple way to rename or delete tags into the latest BETA version 20210301..
This is how it works:
Wow, I can’t wait to try it! Unfortunately I’m not part of the beta program. I look forward to it being released mainstream. Thanks so much Petr!
@MechtEngineer many thanks.. if you like to get the BETA update theer are just 2 steps:
or simply by visiting our Play Store listing and tapping ā€œJoin BETAā€
The update will arrive shortly via Play Store..
