From Xiao Chou on 2016/07/24 07:11:51 +0000
create a alarm repeats mode “every X days”
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/15348510-create-a-alarm-repeats-mode-every-x-days
This! I came here to suggest / request this. I need it!
Reason: I work on shifts that begin on different times of day every day, but the cycle repeats every 10 days. Being able to create a set of alarms that each repeat every 10 days, like I can on Google Calendar, would satisfy my needs so I don’t have to remember to turn alarms on / off or adjust alarm times for the next day.
Hi, it is a bit older topic, but just in case someone still follows this feature request - the new BETA will have the option to repeat every 2-30 days in the non-weekly mode.
To join BETA, follow https://docs.sleep.urbandroid.org/faqs/get_beta.html
I’m now using the new feature, but can’t get to set my alarms consistently for 10-day intervals.
I work on 6 days on/4 days off shifts, so my workdays repeat every 10 days. When I try to set an alarm to start on a date and every 10th day after, the starting date gets skewed to some later date.
Example: I want to set an alarm to start tomorrow (Monday) 21:00, and every 10 day after (so tomorrow Monday, then next week’s Thursday and so on). When I try to select tomorrow Monday, the alarm is set to start on Tuesday. If I try to set it to next week’s Thursday, it is set to next week’s Friday.
I’ve tried several combinations of changing starting dates / nth intervals and can’t make any sense out of it to make it work anyhow.
