Does Smart wakeup works in Alarms only mode?
Does Smart wakeup works in Alarms only mode? While the tracking options are hidden/disabled in the Settings (and per the info message), there is still smart wakeup option to be set in Alarm settings. Does it still works and the app starts tracking 45min before the smart period?
Basically I ask if there is an option to use the app as smart alarm only and do not save stats automatically (technically this can be done with deleting the tracking every morning).
