As the title asks. Thank you!
Does "Record Sleep Noises" need to be enabled to use Anti snoring?
Hi Tom, for snoring recording, you need to have Settings > Sleep noise analysis and Sound recognition enabled.
Sound recording only needs to be enabled, if you wish the sounds to be recorded by the app (for example, if you suspect you might have apnea). It is not required for anti-snoring alerts.
