From Amine Scorpion on 2016/05/26 20:57:00 +0000
let’s consider this situatuon:
- idéal sleep alarm is set
-tracking started using Tasker
-app ideal sleep income set to 8 hours
-app default smart wake up set to 30 min
-alarm set at 8h00
-fall asleep hour is 00h00
in thus context the alarm usually rings between 7h30 and 8h00 (usually 20min window), and that’s less than the ideal sleep income…
the feature requested is… add a not before ideal sleep or alarm time to ideal sleep alarm, independent of the default setting, which affects alarms altogether.
I might be missing something… if it’s possible to achieve the wanted result with the app’s actual settings, than can someone propose a profile please.
Thank you
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/14220282-do-not-ring-before-ideal-length-using-ideal-sleep
