DIY wearable Integration
Hi I’m trying to understand the DIY wearable integration. I see where there is an option to add the APK file for the app. am I to understand that this APK would be for a custom integration that I wrote or is this APK supposed to be the APK of the companion app to the device I desire to integrate?
That’s depend on which device you want to integrate and how you plan to get data from the wearable.
But at least for the smartphone you need to develop APK which sends sleep data to SAA app. Sometimes companion app to the wearable has to be implemented, sometimes not. Depends on the wearable and it’s vendor API.
Hey Den thank you for your response I never saw it at the time I asked the question. I appreciate it
