I can’t find the setting, but remember seeing it before. Sometimes I say screw it and dismiss my alarm but do not wake up, and want it to continue sleep tracking. But when I dismiss the alarm it always ends tracking. Did this setting get removed?
Hi @Mikechicago, it is still there, but not in the general Alarms section. This option can be configured only for specific alarms, so open the list of alarms, open the alarm, and you should see this:
Thank you! No wonder I couldn’t find it. Funny thing is… It is turned off, but still stops sleep tracking when I dismiss the alarm. … I tried turning it on and back off. We’ll see I guess
Do you use automatic sleep tracking? It can be turned off automatically by some major awake-like event.
You can send me the application logs (Left ≡ menu → (?) Support → Report a bug).
@Mikechicago, welcome and thanks for posting to the SaA forum. I’ve been using the app for many years, and have been repeatedly impressed with both improvements in the app and support from @lenka-urbandroid and @petr-urbandroid as well as others. Most recently, they’ve helped me with selection, beta testing and implementation of a great smartwatch, the Mobvoi Ticwatch Pro 5 Enduro. I’m not afilliated in any way with them or the watch company, but enjoy seeing how others are using the systems. I hope it’s useful to you as well. Cheers!
