I dismiss the alarm with Captcha. It says the next alarm is tomorrow morning. But then evey 15 minutes it goes off. I have to dismiss it 3-4 times.
Steps to reproduce:
Steps to reproduce:
Hi @Cahit, you have enabled the Wake-up check either in Settings > Alarms > CAPTCHA > Wake-up check or in the per-alarm settings.
This feature requires a confirmation on the wake-up check notification. If not confirmed, the alarm will start again.
Hi Lenka, that’s true. But the issue is still there. After dismissing the alarm by doing the Captcha, I get the notification asking if I’m really awake. I confirm. The alarm still continues to ring every so often.
It’s quite bad. I have to do 3 Captchas during the first business call of the day.
Could you please send the logs (Left ≡ menu → (?) Support → Report a bug? We do not have any reports so far. On which version are you on at the moment?
