From Anonymous on 2014/11/12 22:25:06 +0000
I’ d like to set off the alarm sometimes for the next morning. Usually I have to go up always at the same time but sometimes I can sleep longer. For this reason I have to disable my normal alarm and set another temporary alarm.
Sometimes I forget to enable again my normal alarm so it would be nice if I can turn it off temporary for the next and for the day after next day its set again
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6708734-disable-alarm-temporary
From Anonymous on 2014/11/13 06:20:29 +0000
Yeah this is what i searched for! Great. Thank you.
