Different QR or NFC for different Alarms
From Artm on 2014/09/27 11:51:49 +0000
Hi guyz.
First of all, let me say THANK you for this useful application.
My idea is in the subject.
Current version has support only one (or more) QR or NFC for all of alarms.
I think it will be useful that users can setup different QR or NFC for different Alarms.
Thanks
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6492189-different-qr-or-nfc-for-different-alarms
From DarienSJ on 2015/02/17 02:54:57 +0000
I REALLY want to be able to specify QR codes (or NFC tags) per alarm! I want to scan bathroom & coffee when I wake up. But I also use a time to leave alarm, and I want to scan my car for that… Please consider implementing this feature.
I would like to be able to do this too. Another great use is putting the QR codes under the lids of specific medications so you can’t turn off the alarm till you open the meds you are supposed to be taking at that time.
I have Idiopathic Hypersomnia, and generally need to take my IH wake-me-up pills 20 to 30 minutes before getting up. As it stands, if I let my phone learn a second QR code for the meds, then I can use that to shut off the “Get out of bed” alarm instead of the code in my dresser. No dice.
Is there any chance that this feature will be implemented in the future? Would be very useful.
Hey hello, sorry for refloating this post, but I would also love if you Urbandroid devs could add this feature soon :backhand_index_pointing_right::backhand_index_pointing_left:.
For now I am using Alarmy because I really need this feature and they have it*, but hopefully you can add it some day :blush:
  • Alarmy also has a very interesting captcha challenge: Photos. You make a photo of your toothbrush in the bathroom and next day when the alarm goes off, you have to make a photo of the toothbrush in the same very position. (This would make you be in front of whatever task you have to do).
(If you think these features do not fit the goal of the app, maybe I would ask you to consider making an app for habits with QR, NFC and photo methods)
Keep up, guys, you are awesome! :flexed_biceps::sparkles:
Hey, I was also looking for this feature, so I’m up voting this suggestion. That would be awesome to be able to select which QR or Bar Code for each alarm. For example I use a QR code in the bathroom for my morning wake up alarm, and tried to register my ADAH medication Bar Code as the captcha for my medication alarm so I don’t take it later since it’s hard to remember. But as it is now I can use any code learnt in settings for any alarm, so I can use the barcode from the medicine to deactivate the morning alarm. It would be perfect if I coulf configure the morning alarm to only deactivate with the QR Code and the medicine alarm to only deactivate with the madication box barcode.
Thanks for taking this into consideration and I would really love a reply from the team telling us if this is possible, if it’s something you guys have under work or not.
Thanks a lot again and best regards,
Igor
Hello! Many thanks for this great app! It has really changed my life, and I would consider donating to help the development of more useful features, such as the separate QR/Bar codes for alarms. I have the same issues as everyone else who has commented on this thread. A response on development progress would be greatly appreciated!
