Dependant alarms
From Joel on 2016/07/23 19:58:03 +0000
alarms that can be dependant on another (I.e. alarm A + fifteen minutes) for those of us using multiple alarms at a time. Prevents from having to change for example 4 alarms at a time and allows you to just change the main one that the others depend on
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/15344250-dependant-alarms
