Deep sleep detection
Just subscribed to the app. I’m still exploring its capabilities and such.
I am not sure about the accuracy of the deep sleep detection. I’m using Polar H10 as the wearable. Sensor tests seem fine (not sure about the accuracy).
The problem is that using the app, it recorded only two events of deep sleep in the entire last week. I don’t think this is correct since I take it I’d be feeling far worse if that was the case. I also wear Polar Pacer Pro watch which shows just under an hour of deep sleep per night throughout the same week.
Do I have something misconfigured on SAA?
Hi @Simonas_Drungilas ´, could you please use the Left ≡ menu → (?) Support → Report a bug, and send us your application logs along with the screenshot of the last resulting graph?
Are there any red sections?
Done.
No red sections if I’m reading it correctly
