[DECLINED] Integration Lemfo Lem 12 Pro as a band
Hi.
Is it possible to change sytuation with full Android smartwaches? can smartwatch be visible as band… like miband. It’s about puls and other functions.
Hello Sajo, we can only integrate devices which allow custom apps on device like Garmin, Wear OS or Galaxy watches etc… or devices which provide their sensoric data though a documented BT characteristics API… Correct me if I’m wrong but Lemfo Lem12 does not have any of those… such devices are usually closed and support a single proprietary app supported by the device vendor…
