From Anonymous on 2016/11/07 15:13:50 +0000
So, the graph seems skewed a bit, one snore with a small line sounds much louder than the huge spike next to it. And really, what decibels of snore are we talking? Is the snore so freaking loud elephants jump in surprise? Or its it more of a muffled snore that wouldn’t wake a mouse but recorded because the phone was so close?
There is no frame of reference if the noise is abnormal or whispered. I cannot tell how loud my snore is.
So maybe you cannot get a decibel reader in, how about lines showing ranges of minor, normal, and wake neighboring country loud?
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/16990711-decibel-counter-or-frame-of-reference-for-how-lou
From Mario on 2017/08/24 19:47:45 +0000
I too would like a follow up on this. A graph without a reference tells no story at all.
If calculating dB is hard, perhaps you could reference to how many times the peak sound is louder than the threshold value
