Dashbord home screen - Sleep as Android
Dashboard home screen is designed to give you just the info you need at a glance. If you find anything irrelevant - just swipe the card away to create space for relevant content.
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org//ux/hs_dashboard.html
Hi, I accidently removed stats from my dashboard and can’t figure out how to add it back. Thanks for the help.
Hello @Nathan_Barash, please scroll all the way down on the Dasboard.. there is a “hide / show” option where you can add any card you have hidden previously back to be shown on the Dashboard..
