Dashbord home screen - Sleep as Android
Dashboard home screen is designed to give you just the info you need at a glance. If you find anything irrelevant - just swipe the card away to create space for relevant content.
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org/ux/hs_dashboard.html
Hi! Is it possible to rearrange the cards in the dashboard, or can we only pin/unpin? Also, can we rearrange the order of the ‘Shortcut’ alarms in the dashboard?
Same question for me! I know we can pin but i see more value in being able to reorder the cards rather than a random logic.
