Vibration can be controlled only from the companion app, because the integration with MiBands is not direct (the API is not available for the integration). Luckily, both companion apps allow vibration customization in the pro versions.
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org//faqs/miband_vibrations.html
