Option doesn’t appear
Also cannot find it. I want to connect it to the lights connected with google assistant.
You need the beta
Hello, many thanks for your interest…
or simply by visiting our Play Store listing and tapping “Join BETA”
To discuss BETA channel related issues please use our forum at: https://forum.urbandroid.org/c/beta
Please let us know how you like the feature…
Hello team,
Thank for setting up automations. I am using it to control my lights and is working fine with IFTTT. But I am unable to use it with custom webhook. I have basic authentication setup on the endpoint but every request goes unauthorized.
I have added the URL in the form https://myuser:mypass@domain.com/sleep but my server always give me 401.
Could someone please clarify? I cannot make sense of the link between Sleep as Android, Webhooks and Home Assistant.
Which URL ( https://myuser:mypass@domain.com/sleep) do I use in SaA?
Sorry if this seems naive, I could not find an answer on the web
Is it possible to send a GET event ?
