Custom actions in notifications
I’ve been using Twilight for a long time on my Amazon Fire HD tablet, and recently purchased the Pro Unlock (I actually thought I had already done that).
One thing I’d really like is if the notification actions could be customized by the user. The settings popup works, but usually I just want to swap between one of my two profiles. So, it would be fantastic if I could do so directly from the notification. As it is now, I have to tap the notification, then tap the Profiles dropdown to select the profile, and then tap to accept the changes.
It’s a minor thing, but I thought I’d suggest it in case it’s helpful to others.
